logan55
Feb 04, 2023Follower
RBR750 dropping internet after 10 mins of every reboot
I am forced to use Comcast Xfi Modem to avoid paying extra for unlimited data.
But I have Wifi turned off on the comcast modem and instead I am using 3 Orbi's in AP mode.
The setup has been working smoothly since several months. However since today morning my Orbi keeps on dropping internet and turning purple. Then I unplug and replug the Orbi router and it works perfectly for ~10 mins only to drop internet again.
Things I have done so far:
Updated to the latest firmware: 4.6.14.3
Factory Reset the Orbi
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Is the RBR using a Dynamic or Static IP address configuration in AP mode? Static is recommended.
Is the Front LED on the RBR turning on PINK?
Be sure the ISP modems WiFi radios are fully disabled...
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many? - KevinLiTNETGEAR Moderator
Hello logan55,
Welcome to the NETGEAR Community!
Are you still having network connectivity issues with your RBR750?
Best,
Kevin
Community Team
