AggedwNG
Aug 15, 2021Apprentice
RBR750 dropping internet connection over ethernet
Having issues with Orbi RBR750 2 weeks after most recent fw. No changes have been made since fw update. Today it started dropping internet connection while connected directly to ethernet, with a solid magenta light on the front. I have been trying to update my desktop with a windows update which has hosed my image twice. Everytime I try to download the update, after restarting the orbi to restore internet connection, it drops and then turns magenta and will not allow anything to connect to the internet or me to connect to the orbilogin page. I have verified ISP connectivity is fine. After a hard reboot of the router connectivity is fine. Until I try to download anything using any of the ethernet ports. Is this router or the fw bad?
- AggedwNGApprenticeRouter firmware is v4.6.3.7_2.0.49
RBK752 bundle: 1 RBR750, 1 RBS750
Network Connectivity is as follows:
Frontier Fiber ONT -> RBR750 via ethernet from ONT (RBR750 is setup in Router mode, VLAN/Bridge mode disabled, traffic monitor disabled, ipv6 disabled) -> RBS750 connected to RBR750 via wireless backhaul.
5 wireless devices connected, 1 wired device connected to RBR750 via ethernet. - FURRYe38Guru - Experienced User
IF the RBR is showing Pink front LED, this means the RBR is loosing the connect to the ONT or the ONT is loosing connection to the ISP services.
I'd make sure the ISP service line up to the ONT is to spec.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure to power OFF the modem/ONT for 1 minute them back ON along with the RBR.- AggedwNGApprenticeThanks Furrye38 for your suggestion. Was on the phone with their 1st level support most of the day as this was initially my 1st suspicion. However, they could not find anything suspect along the service line to the ONT and I was able to rule out any issue from the line into the house testing with a 40gb download after bypassing the router, going direct connect from line in to the house to desktop, which completed successfully. After testing, powered off Router and Sattelite, rebooted ONT manually and left ONT disconnected for 3 minutes for a clean reset, then reconnected while leaving RBR/RBS750 disconnected for 10 minutes, then reconnected and powered back on. Once router and satellite were synced, retested again with a 5gb file download this time (connected desktop to router via ethernet) and it crashed within the first 1gb of download (internet dropped out, light went solid magenta on router and only the router oddly I must add). When this happened everything on the network that was connected dropped immediately, no matter wired or wireless and was unable to login to admin portal nor get connectivity back until a hard power cycle of the router. I was able to replicate this 2 additional times thereafter. Streaming was not impacted though, on my wireless devices (Rokus) if just doing only that. Seems to be only when trying to download anything while wired to the router. Tried also downloading another smaller file to my work laptop (app update pushed out) and it crashed again as well after ~300 MB's downloaded. Performed various speed tests throughout, but only mentioning in case it helps (from router to ookla average - 615 down 930 up, bypassing router direct line in from ONT to ookla average - 920 down, 930 up). I am also using mac filtering via access control which I forgot to mention, if this helps at all.
- AggedwNGApprenticeAlso tried connecting a gaming console wired via ethernet to the RBR750 and downloading a 7gb software update, 2-3 minutes in, hard crash.. Decided to swap out my RBR750 with my old Asus RT-AC68U after resetting every link in the chain and test with this.. Wired a ps4 to the AC68U, downloaded various software updates (~20 gb total), no issues. Pulled the RT-AC68U, reset the ONT, reconnected the RBR750, synced back up with the RBS750, restarted the ps4 and wired in to the RBR750. Crashed again, ~230 mb's in to downloading a game.
