AggedwNG
Aug 16, 2021Apprentice
RBR750 dropping internet connection over ethernet
Having issues with Orbi RBR750 2 weeks after most recent fw. No changes have been made since fw update. Today it started dropping internet connection while connected directly to ethernet, with a solid...
Sep 05, 2021Guru - Experienced User
Good Luck.
AggedwNG
Sep 06, 2021Apprentice
Thanks. I do appreciate your help though. Glad there are some people in alternate venues trying to assist with this. Too bad you don't get paid by netgear, you've done more legwork than their QA and from a consumer standpoint, it is appreciated.
- FURRYe38Sep 06, 2021Guru - Experienced User
đ
- Ptown2002Nov 30, 2021Aspirant
FURRYe38 AggedwNG Have you figured this out? I'm having the same issue, but it had been happening when I try to download updates through Adobe Creative Cloud. Fast forward to today, I tried to install Halo Infinite through Steam and the download crashed my router again. Orbi mesh system is the RBK753S.
- FURRYe38Nov 30, 2021Guru - Experienced User
Something to review here as some others are seeing this crash on the RBR when downloading large size games:
Contact NG support and let them know what your seeing.
