DennisMaxx's avatar
DennisMaxx
Apprentice
Oct 07, 2021
RBR750 Guest Network visible while guest network is disabled
Hi,
I have an issue I can't solve. I use Orbi RBR750 + 2 Satellites (RBS750). All devices have V4.6.3.16_20.51 installed.
Once in a while my Devices are loosing WiFi Connection. When this happens, I can see "netguer Guest" in the available WiFi Networks despite I have turned off Guest Network.
Sometimes this happens 5 times in 60 minutes, sometimes only once a day. During online communication it is very dissappointing to lose connection and reconnect.
Another Problem: Some devices are 1 meter away from the Satellite but still connects to the Router which is one level / floor below. It helps to restart the device to connect to the satellite but after a few hour, it reconnects to the Router.
In addition I can recognize the blue LEDs on the Satellites multiple times a day...
Settings: 2.4G & 5G available, WMM enabled, 20/40 MHz Coexistence enabled, Router Mode, VLAN off.
Is there any help? What can I do?
What I did so far: Reset to factory settings, repositioned the Satellites, nothing changed.
  • Has a factory reset and setup from scratch been performed since last FW update?
    You might try this:
    https://community.netgear.com/t5/Orbi-WiFi-6/New-RBR750-RBS750-Firmware-Version-4-6-3-16-Released/m-p/2148326/highlight/true#M21276
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    • Thanks for your reply.
      Yes, after factory reset I started from new (configured WiFi Name, Password and so on). I'm from Germany, my ISP is "Deutsche Telekom" and the modem is "Fritz!Box 7490 with latest OS.
      Our home is about 85 square meters, RBR (1st floor) and RBS1 (2nd floor) are in a distance of 3,5 meters in a straight line but through a concrete ceiling. RBS2 (0th floor) is about 7 meters away through wooden stairway.
      Channels are configured in: 2,4G is on channel 1, 5G is on channel 36. After weeks of testing this was the most stable variant.
      WiFi neighbours are there, I can find 5 other Networks in 2.4G area, but nothing in 5G.
      My problem is not the performance, when it is working, everything is fine. My problem is, that it keeps kicking out my iPhones and iPads and Laptops (HP Elitebook as well as MacBook). Yesterday I renamed "Netgear_Guest" to something different (new name: TestWiFi), because it could be, that some other neighbour uses this. But now when my iPhone gets kicked out I can see Guest-Network "TestWifi", so it has to be my Orbi which is sending out "Guest Network" for a short time although it is set to OFF.
      • Another thing I saw today: RBS resets itself. White light is blinking, then after a while, blue solid light is visible. Why is it doing that??
        Keep losing my connection.
