dbrb2
Jul 19, 2025Apprentice
RBR750 Internal server error
Damn. 2 nights ago my RBR750 started showing an error 500 interal server error It still works as an AP, but the satellite will not connect - so half the wifi is down A power cycle had no e...
dbrb2
Ah I should clarify - when I say remote - I am actually technically local - I am port forwarding in over SSH
Both the RBS and the RBR get IPs over DHCP
But the RBR gives a 500 if I try to load the main web page
The RBS asks for a login, but then loads an empty page when the correct credentials are entered
I guess one take-away from this is to turn off auto firmware updates (I don't know that was the problem, but seems likely as nothing else has changed recently....)
