dbrb2
Jul 19, 2025Apprentice
RBR750 Internal server error
Damn. 2 nights ago my RBR750 started showing an error 500 interal server error It still works as an AP, but the satellite will not connect - so half the wifi is down A power cycle had no e...
dbrb2
No luck with debug mode. Some pages though do still respond:
ben@pi5:~ $ curl -s http://192.168.1.15/ajax/qos_link_check.php --data-raw check_bw=check
speedtest stcurl -s http://192.168.1.15/ajax/qos_result_check.cgi --data-raw check_bw=check -X POST -H 'Content-Length: 0'tent-Length: 0'
speedtest is running
Some time later....
ben@pi5:~ $ curl -s http://192.168.1.15/ajax/qos_result_check.cgi --data-raw check_bw=check -X POST -H 'Content-Length: 0'
99.99 Mbps;964.73 Mbps;2025-07-19 22:33:49ben@pi5:~ $
So the unit is there and functional - to some extent.
I power cycle remotely using a PoE managed switch - since both the RBS and RBR run from 12v PoE splitters (and have done for years)
I've tried various browsers, incognito modes, and chache clearances unfortunately
