dbrb2
Jul 19, 2025Apprentice
RBR750 Internal server error
Damn. 2 nights ago my RBR750 started showing an error 500 interal server error It still works as an AP, but the satellite will not connect - so half the wifi is down A power cycle had no e...
dbrb2
Yep - you're right about the firmware. So the RBS problem was not caused by an auto firmware update. RBR maybe was - but I can't check that :-)
However, in my attempts to fix this evening I downloaded RBS 7.2.7.15 and uploaded that to the RBS - and that made things worse (404 error on the RBS now)
Those are the only ajax examples / URLs I have I'm afraid - though I have used them for ages to periodically check my speeds
