dbrb2
Jul 19, 2025Apprentice
RBR750 Internal server error
Damn. 2 nights ago my RBR750 started showing an error 500 interal server error It still works as an AP, but the satellite will not connect - so half the wifi is down A power cycle had no e...
CrimpOn
Jul 21, 2025Guru - Experienced User
dbrb2 wrote:go for a pair of Cudy WR3000S
VERY confused. This seems to be inconsistent with
dbrb2 wrote:I am port forwarding in over SSH
If you have physical access to the system, what is the reason for not doing a Factory Reset and configure from scratch?
dbrb2
Jul 22, 2025Apprentice
I could, but I've done that a few times over the last few years, and whilst it has worked, it's a faff each time. So I thought I'd try a different approach
