claudiut's avatar
claudiut
Apprentice
Jan 05, 2023
RBR750 regular reboot or not?
Hello,
I have a RBK753 system (RBR750 router and 2 x RBS750 satellites) and it's been pretty stable for the last while after a long period of issues with bad firmware (v4.6.5.14) I'm currently running v4.6.9.11 and it's been up and w/o issues for more than 48 days. I was wondering if anyone is doing a regular reboot of their system (router/satellites) and if doing a regular reboot improves the system' stability. Also, I don't see an option for a scheduled reboot in the web management UI, so I guess it needs to be done manually, right?
Thanks!
  • Regular reboots should not be needed. If there needed then something needs to be checked. Routers should not need any reboots for normal operation.
    I've had my 7 series online for going on a week now on FW v.3 and is working just fine.
  • CrimpOn's avatar
    CrimpOn
    There is no user option to schedule reboots. My WiFi router has been up for as much as six months at a time, only restarting when Edison treated us to an eight hour power outage that was too long for the UPS to remain alive.
  • FURRYe38's avatar
