TJ_Ho
Mar 21, 2025Aspirant
RBR750 regular reboot required since firmware update
I find that I constantly have to reboot the router since firmware updated.  V7.2.6.31_5.0.24  Any suggestions?
- Mar 21, 2025
Hello TJ_Ho,
Welcome to the NETGEAR Community!
I understand that you are having reboots with the FW v7.2.6.31 on your RBR750. Please update to the most recent FW release v7.2.7.15. Please be sure to update the satellite first.
Please navigate to the link below to manually download the FW v7.2.7.15:
https://kb.netgear.com/000066598/RBR750-RBS750-Firmware-Version-7-2-7-15
Please follow the directions in the video embedded in the link below to successfully update your satellites:
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satelliteNavigate to the link below for additional update instructions for your Orbi system:
Best,
Kevin
Community Team
TJ_Ho
Third try was successful. Different instructions for router. Sorry for the brain damage.
Mar 21, 2025Guru - Experienced User
Can use this PDF guide file process next time for a manual FW update:
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
