JackStir
Jul 11, 2024Aspirant
RBR750 satellite (RBS350) does not show up in attached devices
Hello, I just purchased the Orbi RBK652S system 7/6/24. I have owned ASUS routers for the past 10 years so I am still trying to learn this system. I was using the Orbi app the next day (7/7) and noti...
Jul 11, 2024Guru - Experienced User
What FW version is on the RBS and on the RBR750?
Be sure that you don't update the RBR750 to any v7 version of FW as that is NOT compatible with RBS350.
If the RBR750 was update to v7, you'll need to downgrade the RBR back to v6 version listed in the link posted.
- JackStirJul 11, 2024Aspirant
I am on firmware version V7.2.6.31_5.0.24. I do not know what version the RBS is on. It is not listed as an attached device.
