RickML
Jul 23, 2026Guide
RBR750 stuck on older firmware branch – Update check returns nothing, manual file rejected
Hi everyone, I’m running into a brick wall trying to update an Orbi AX mesh system (RBR750 router with matching RBS750 satellites) that appears completely locked to an older firmware branch. ...
RickML
Jul 23, 2026Guide
Re-posting reply as it disappeared.
I purchased it from Amazon, Aug. 2025:
NETGEAR Orbi Whole Home Tri-Band WiFi 6 Mesh Network System (RBK752P) – Router with 1 Satellite Extender, Security Features, Coverage up to 5,000 sq. ft., 75 Devices, AX5200 802.11ax (Up to 5.2Gbps)
https://support.netgear.com/support/product/rbk752p shows:
RBR750P (Orbi Router) Firmware Version 6.3.8.5 Latest
RBS750P (Orbi Satellite) Firmware Version 6.3.8.5 Latest
There is no firmware upgrade path here and as another pointed out there is no v6.3.85
schumaku
Jul 24, 2026Guru - Experienced User
RickML wrote:I purchased it from Amazon, Aug. 2025:
So a slightly stripped-down 2.4 GHz radio, making it AX5200, while the RBK763S, RBK762S, or RBK76xS is AX5400 - made up from RBR760 (router), and RBS760 (satellite(s)).
RickML wrote:https://support.netgear.com/support/product/rbk752p shows:
https://www.netgear.com/support/product/rbk762s shows:
RBR760 (Orbi Router) Firmware Version 6.3.8.11 Latest
RBS760 (Orbi Router) Firmware Version 6.3.8.11 Latest
Tricky comparision with the many different Orbi variants in the various retail and eshop channels.
RickML wrote:There is no firmware upgrade path here and as HappyCat pointed out there is no v6.3.85 in the RBR750P or RBS750P
RBR750P and RBS750P are cost-down siblings to the RBR760 and RBS760, -not- from the RBR750 and RBS750 as HappyCat assumed.
HappyCat wrote:The Netgear web site does not show any 6.x firmware, so I am wondering if this came from an Internet Service Provider and is "locked" to their firmware:
The RBR750/RBS750 system is (or was) AX4200 - so wrong comparison, and unrelated in the Orbi family tree 8-)
