r1igby
May 27, 2024Aspirant
RBR750 System is dying
I have a RBR750 system with 2-3 RBS750s depending on if they work, and for the most part, it was doing working relatively well. I think it automatically updated the other day to 7.2.6.31 and everything has been broken since then. The Wi-Fi is being horribly inconsistent and is dropping out every couple minutes. The satellites are also unable to stay connected and almost consistently are pink. In the computer software, the status for the satellites is almost always "disconnected", or for the rare occasion when it is connected, it says "out of sync" for the backlog status. If anyone knows how to fix this, that would be great.
We have consistent 1 gig internet so that is not the problem. Seems to just be another problem which always comes with Orbi systems.
1 Reply
Any time I see an issue after a firmware update, I recommend a factory reset and a clean install. By clean install I mean don't install using a backup.
