OahuOrbi's avatar
OahuOrbi
RBR750 Throttling Bandwidth
I have an Orbi RBR750 and it's been working fine up until recently.  Firmware is up to date, however it's throttling my bandwidth and I'm not sure why.  Direct connection between modem and computer gives me the fastest speeds, but when I go through the Orbi the bandwidth is throttled.  I'm connected via Ethernet cable, so it's not a wifi issue, however turning on the wifi yields the same result.  Yes, I've tried restarting both, but nothing seems to work.
  • FURRYe38's avatar
    • OahuOrbi's avatar
      OahuOrbi
      Latest Firmware: V4.6.8.5_2.1.9
      EN2251
      Hitron Tech
      • FURRYe38's avatar
        What is the CAT# lan cable between the modem and router? CAT6 is recommended.
        Is Armor or Parental controls enabled on the RBR?
        Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
        Turn off and unplug modem.
        Turn on computers and rest of network.
