DonMacGregor
Nov 06, 2025Aspirant
RBR750 Throttling WiFi to 100mbps on Gigabit Connection
I hope someone can provide some insight. I currently have an Orbi mesh system set up in my house. One RBR750 router, and 3 RBS750 satellites. The RBR750 is connected to a Nokia XS-2426X-A gigabi...
DonMacGregor
That is correct. FW version on the RBR is V7.2.7.15. I have already ordered all new CAT 6 cables and plan on swapping out everything. Just verified the current cables are 5e. Both the patch cable from the modem to the switch, and the cable from the switch to the RBR.
- FURRYe38Nov 06, 2025Guru - Experienced User
Try connecting the RBR behind the Nokia router then switch after the RBR.
Does the RBR web page under Advanced tab/Show Stats show 100Mbps or 1000Mpbs for the WAN port speed?
- DonMacGregorNov 06, 2025Aspirant
WAN Port Status says 1000M/Full
What is connected on LAN3 port at 100Mpbs?
So connecting the RBR behind the Nokia router then switch after the RBR.
Test with a ethernet connected PC behind the RBR.
