DonMacGregor
Nov 06, 2025Aspirant
RBR750 Throttling WiFi to 100mbps on Gigabit Connection
I hope someone can provide some insight. I currently have an Orbi mesh system set up in my house. One RBR750 router, and 3 RBS750 satellites. The RBR750 is connected to a Nokia XS-2426X-A gigabi...
Nov 06, 2025Guru - Experienced User
Try connecting the RBR behind the Nokia router then switch after the RBR.
Does the RBR web page under Advanced tab/Show Stats show 100Mbps or 1000Mpbs for the WAN port speed?
DonMacGregor
WAN Port Status says 1000M/Full
- FURRYe38Nov 06, 2025Guru - Experienced User
What is connected on LAN3 port at 100Mpbs?
So connecting the RBR behind the Nokia router then switch after the RBR.
Test with a ethernet connected PC behind the RBR.
