RockTheGlobe
Jul 03, 2025Apprentice
RBR750 where the system will randomly reset/reboot itself a few times a week
I've been having a similar issue with my RBR750 where the system will randomly reset/reboot itself a few times a week (literally just happened a few moments ago). This started happening after the lat...
Jul 03, 2025Guru - Experienced User
Does the front LED turn PINK or blink WHITE when this happens?
Do you have Ipv6 enabled?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How was FW updated on the system? Updated via Auto Update or manually?
Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
How many RBS are deployed?
Armor, Guest Network, Smart Parental Controls or Circle, IPv6, Protection Engine, Traffic Meter.
What channel configurations are currently set on the router?
