codynet
Oct 17, 2021Aspirant
RBR750 WIFI - fast upload but slow download
I just purchased an RBR750/RBS750 and have it on latest firmware (V4.6.5.14_2.0.54). I have the router hooked up to my gigabit ethernet. When I run speedtest (speedtest.net- not the one built into the admin panel) from my laptop on wired RBR750 connection I see ~830Mbps down / ~909Mbps up. Great.
Problem is when I move to wifi (802.11.ax connection at 1201/1201 link speed), I see ~330Mbps down / ~790Mbps up. I decided to try wiring my laptop to the satellite with wireless backhaul to see if that would help. I got 322Mbps down / 845Mbps up. The upload / download disparity is bugging me. I tried disabling WMM, moving to insecure network, factory reset, etc. but the discrepancy remains. Any explanation out there for that, and hopefully some way to resolve?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Whats the wireless device your speed testing with?
Whats the connection rate between this wireless device and the RBR?
- codynetAspirant
V4.6.5.14_2.0.54
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Calix 711GE ONT
MSI and Alienware gaming laptops (both have 802.11ax wifi cards and gigabit ethernet ports). I speed tested the following two configurations and noticed the download/upload speed discrepancy for each configuration on both laptops:
- Laptop to RBR750 (router) over wifi
- Laptop wired to RBS750 (satellite) connecting to RBR750 via wireless backhaul
The discrepancy does not exist with direct wired connection to RBR750.
When connected over wifi, the laptops are showing 1201Mbps/1201Mbps connection rates.
- codynetAspirantAny ideas?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.Any Wifi Neighbors near by? If so, how many?
Have you disabled AX mode on 2.4Ghz?
Also try using manual channels 11 and 48.
Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Has a full facory reset and setup from scratch been performed since last update?
Others have mentioned a reset has helped them. You may need to factory reset the system and power the system OFF as well.
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150287/highlight/true#M21560
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150391/highlight/true#M21575
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150417/highlight/true#M21579
I would presume your system maybe faulty. You should open up a support ticket with NG support and let them know what your seeing.
