DrInfoman
Sep 29, 2021Aspirant
RBR750 WiFi 6 Mesh - Switches From Ethernet to WiFi and Back Several Times A Day
I have an ethernet going from the router (RBR753 - 750 and two satellites) to my laptop, and all had been fine for a while. Now, in the last 2 day, it's constantly dropping the ethernet and goes to WiFi - then back to ethernet almost immediately. It's an issue, but more of a major annoyance than anything.
Anyone else have any insight to this? Happening to anyone else? Firmware is up to date.
Thanks...
Andy
Hi!
No LAN switch in-between, using CAT7 cables.
But I think I have resolved it. The cable going from the router to my laptop - I don't think it was connected "100%" to the laptop - only "partially" (wasn't "clicked in") - removed it and redid it, and so far, no hiccups.
Thanks!
Andy
Are the RBS directly ethernet connected to the back of the RBR or is there a LAN switch in between.
Besure your using good quality LAN cables, CAT6 is recommended.
- DrInfomanAspirant
Hi!
Thanks!
Andy
Glad that was all.
Please mark your thread as solved so others will know.
Enjoy.
