mduds
May 19, 2025Aspirant
RBR750 Wifi Connectivity Suddenly Intermittent and Weak in One Room
I have had the RBR750 router and satellite for about 2 years. Recently, in the past few weeks, we've started experiencing wifi connectivity issues in one room of the house. It started about a month a...
May 20, 2025Guru - Experienced User
Is the Computer in the remote location wireless or ethernet connected to the system?
Be sure that any wireless or ethernet adapter drivers are updated on the computer.
Be sure your using a good quality LAN cable between the modem and router. CAT6 UTP is recommended.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/kb/en-orbi-knowledge-sharing/netgear-mobile-applications-and-androidapplewindows-devices-faq/2457046
