mduds
May 19, 2025Aspirant
RBR750 Wifi Connectivity Suddenly Intermittent and Weak in One Room
I have had the RBR750 router and satellite for about 2 years. Recently, in the past few weeks, we've started experiencing wifi connectivity issues in one room of the house. It started about a month a...
mduds
May 20, 2025Aspirant
Computer is wireless - but it’s not just the computer. All devices going into that room are experiencing the connectivity issues.
No modem - it’s an Ethernet connected directly to the orbi router and then there is a satellite connected to the router.
One router and one satellite - approx distance between the two is 30-40 ft.
Not sure about the channel configurations, where I would look for that, and what it would tell me if I looked. How would that information be of assistance?
May 21, 2025Guru - Experienced User
Log into the RBRs web page at 192.168.1.1.
Also check the web page for connected devices, do you see your devices connected at the RBR or RBS when your devices are in the remote location?
Also be sure to disable wifi on the devices for 5 seconds then re-enable it at the remote locations so they get connected with the RBS at that location.
