carpeDiem3
Jun 08, 2022Aspirant
RBR750 wifi drops all the time every 2 minutes or less
I am using 2 Orbi RBR750's with a total of 4 satellites, both of the RBR750s are used as access points connected to separate ports on my Firewalla. with separate IP ranges and isolated from each other. the 5 g channels are set separate from each other , one is 36 and the other 48, 2.4 is set to auto. So I use one with 3 satellites for my home and one with one satellite for my guest network. ( all in the same space)
Ever since I setup the second one for the guest setup, it constantly drops the Wi-Fi network, I mean every minute.
home network runs on V4.6.8.2 (pushed update from Netgear due to the update problem)
guest network runs on V4.6.5.14 and I don't know where to download the newer version.
Has anyone seen this problem before or has an idea on how to fix this ?
thank you
carpeDiem3 wrote:
I am using 2 Orbi RBR750's with a total of 4 satellites, both of the RBR750s are used as access points connected to separate ports on my Firewalla. with separate IP ranges and isolated from each other. the 5 g channels are set separate from each other , one is 36 and the other 48, 2.4 is set to auto. < channel 1 should be set on one RBR and channel 11 should be set on the 2nd RBR. So I use one with 3 satellites for my home and one with one satellite for my guest network. ( all in the same space)
Whats the size of this home? Sq ft.
Having too much wifi signal running can cause problems:
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡You also may need to turn down the power out put of the 2nd system to 25% and maybe set the 1st system to 50%.
Guest Network would not be on or should be on a different FW version. AL RBR and RBS should be on same version FW level.
Has anyone seen this problem before or has an idea on how to fix this ? No. I can run two Orbi systems. However channels, distances and transmit power need to be configured correctly.
- carpeDiem3Aspirant
What's
the size of this home? Sq ft. Having too much wifi signal running can cause problems:
it is about 5500 sqft serving 2 living spaces
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
they all are 20 to 30 feet apart depending on the obstacles in the way , but its the router that is disconnecting , so the satellite is not even in the picture
they are running independent on separate channels
I wish I could but Netgear pulled V4.6.8.2 from their side (due to issues) prior to me installing the second network , and it specifically states not to downgrade from this version
I am almost certain that I configured it correctly , still the issue persists.
- DarkNetApprentice
Just curious. Why do you use two RBR’s? Why not one RBR and utilize the guest network on it?
@ DarkNet
I use a firewall/ router to manage the entire network , if I use ORBI as another Router it wont give me insight into the network as it is not showing me a complete picture. My Firewall manages all groups/rules/VLANS/IP reservations/DHCP/security etc . So for that reason I use orbi as an AP and I cant use it as a guest network. interestingly enough I tried that once and all guests get an IP which does not show up on the FW. So using the second AP / Orbi Router is for another network port on a guest Vlan.
Not all devices on Wireless have the same rights on my network.
Hope that explains that a bit
