djdodge
Jul 17, 2022Follower
RBR750 wireless not working
I have the same issue and have been for about 6 months. Everything works fine and then a device can see the main Wifi but no internet connection. Switch to guest Wifi and it works fine, try and switch back to main Wifi and still not connection. If I reset router it will all work for a week or so and then it starts again. If I leave devices on guest Wifi they do not have any issues.
My house is small, so I do not have a satellite running just my main router, Wifi strength is great on all devices. Firmware is V4.6.8.2
I am not a router expert, could someone please share steps to "Set orbi router to AP mode" or will that not help in my case because I am not running any satellites?
Thanks for any help, love the Orbi until this issue started happening.... Would love for it to work flawless like it originally did.
1 Reply
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?You might update FW to v.5 as well and see if anything changes:
AP mode:
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
