luke123456789's avatar
Aug 21, 2025
RBR750 won’t connect to the internet
Hello
I have an Orbi RBR750 and satellite system in my home and the router will no longer connect to the internet. I have tried to factory reset the router but this has had no effect.
i have checked my connection using the router my ISP has supplied and their router works fine. I have owned this system for around 3 years and had no issues to date (beyond some minor connectivity issues, which resolved themselves).
the system just shows a purple/magenta light and no amount of turning off or resetting the router seems to work.
Any help would be greatly appreciated
thank you
1 Reply
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
    https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
    https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Try option #2 first...
