MalV
Mar 12, 2026Aspirant
RBR750/RBS750 Firmware Question
Hi All, Have the RBR750/RBS750 system. The Orbi app does not work on my Android phone, just a white screen. Support stated my firmware is not up to date on my systems, so probably that is why app...
- Mar 16, 2026
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
CrimpOn
Mar 12, 2026Guru - Experienced User
I believe you can just go directly to the latest firmware. It is absolutely critical that the satellite(s) are updated before the router.
