MalV
Mar 12, 2026Aspirant
RBR750/RBS750 Firmware Question
Hi All, Have the RBR750/RBS750 system. The Orbi app does not work on my Android phone, just a white screen. Support stated my firmware is not up to date on my systems, so probably that is why app...
- Mar 16, 2026
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
MalV
Mar 13, 2026Aspirant
Thank for the replies. I did not know you can go back a few versions. I was thinking after posting this, perhaps jump to the last v4.x version, first v7.x, then latest v7. I missed calculated as I doubled counted the firmware versions. I'm behind 5 version for both router and satellites.
