MalV
Mar 12, 2026Aspirant
RBR750/RBS750 Firmware Question
Hi All, Have the RBR750/RBS750 system. The Orbi app does not work on my Android phone, just a white screen. Support stated my firmware is not up to date on my systems, so probably that is why app...
- Mar 16, 2026
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
MalV
Mar 15, 2026Aspirant
Thanks all for your help. I'm happy to say I'm now at V7.2.8.5 for my router and satellites.
- FURRYe38Mar 16, 2026Guru - Experienced User
Enjoy. 📡
