Fishfriendz
Jan 26, 2024Aspirant
RBR750/RBS750 unable to download firmware update
I am trying to update my firmware based on the email I received yesterday. My app as well as orbilogin says no new firmware available (v4.6.14.3) even though I know there is an update (v7.6.2.21). ...
Jan 26, 2024Guru - Experienced User
Be sure your downloading both RBS and RBR FW files, there are two.
Be sure your unpacking the FW files from the .zip file to reveal the actual FW files themselves.
Use the RBS web page to send the RBS FW file.
Then use the RBR manual FW update page to update the RBR using the RBRs FW file.
Clear out all browser caches prior to entering the web pages.
Fishfriendz
I cleared my cache. I re-downloaded the RBS750 file first. When I extracted it, I get a chrome document and then a .chk file that says file fragments. I attempted to use that file but got a "firmware update failed. please check your file." I followed the manual process but was unable to get past uploading the firmware.
- plemansJan 26, 2024Guru - Experienced User
Have you tried a different pc?
- FishfriendzJan 26, 2024AspirantI don’t have another one to use
- FURRYe38Jan 26, 2024Guru - Experienced User
After unpacking the fw file from the .zip. DO NOT attempt to open this file with any browser or application.
Go directly in to the RBS web page and use the RBS FW update feature seen there and navigate out to where this file is and just highlight it. Then select OK and the select the update button.
If you don't have another pc, you can also try a different browser.
Or you can even try doing it on your phone using its browser. Little more challenged to extract the file on your phone before uploading it
- FishfriendzJan 26, 2024AspirantWhere is the RBS update page? When I click update on the orbilogin page, it takes me to an IP address log in. My Orbi login does not work.
- FURRYe38Jan 27, 2024Guru - Experienced User
Reveiw this on how to get to the RBS web page and log in and update FW:
