StefanoVolpi's avatar
StefanoVolpi
RBR760 - Problem sync pc time
I noticed that the various computers, laptop that are connected, both via wifi and cable, are unable to synchronize the time (time synchronization failed. Please check your network connectivity and try again). After various tests, I connected directly to the provider modem and the synchronization occurs correctly. I therefore deduce that the problem is the RBR760 router itself.
The only way to have pc time synchronization is to configure the RBR760 as an access point, but this doesn't seem like an appropriate solution considering that I also have a satellite (RBS760).
Do you have any suggestions?
Stefano
