gmcotton
Aug 26, 2025Guide
RBR760 confusion
I just upgraded(?) from my RBR50 system that was running 2 access points. One with 3 satellites, the other with one satellite. Each AP had separate SSID and password. I purchase one RBR60 syste...
CrimpOn
Aug 26, 2025Guru - Experienced User
The Bell 3000 is definitely a router:
https://support.bell.ca/internet/products/home-hub-3000-modem
The AX products are more sensitive to connection methods than the older WiFi5 Orbi system.
Is it correct to assume that:
- Each of the RBR760 units has the WAN port connected to the Bell 3000?
- The RBS760 satellites are connected to their routers using the default WiFi connection (not 'wired')?
- The two RBR760 are set to static IP on the router itself (not using a feature on the Bell 3000 to 'reserve' IP address for them)?
