gmcotton
Aug 26, 2025Guide
RBR760 confusion
I just upgraded(?) from my RBR50 system that was running 2 access points. One with 3 satellites, the other with one satellite. Each AP had separate SSID and password. I purchase one RBR60 syste...
gmcotton
Aug 26, 2025Guide
Good day,
I figured it had something to do with the WiFi5 vs WifI6.
Fully aware that the 3000 is a router - That's why the RBR 760s are configured as APs
I used the Orbi app to add the satellites to 760#1
I then added the second 760 as AP only no satellites.
Each 760 is hardwired to the 3000 router by their WAN port. #2 VIA a fbre cable with converters.
Eadh 760 has a static IP configured in its settigs using the web interface advanced AP settings. The HH3000 doesn't have a setting for fixed. Current plan is to use the 3000 to provide a DMZ connection to OpenSense router that will then feed the network.
