orbi_guy's avatar
orbi_guy
Follower
Jun 24, 2025
RBR760 firmware for WPA2/3 support
The Orbi iphone app (v2.45.1.1), WiFi Settings -> security Method choices are limited to 4 options (None, WPA2, WPA/WPA2, WPA3).  Some of my devices do not support WPA3, so I was looking for one that...
  • FURRYe38's avatar
    If you have a need for WPA3, you'll probably need to find a different Orbi system. Models 750, 850, 960 and all BE series now have mixed mode support. I think the 760 series was a limited run and and not givin long term development.
