Jjersey63's avatar
Jjersey63
Apprentice
Aug 08, 2022
RBR760 Satellite via web page
Weird issue - wren I look at my web page for connected devises both my satellites show disconnected however, they are listed 126 times - 2 MAC addresses but repeated many times.  Nothing shows connected but I know they are as I can web to them.
The app only shows my router when I use the network map.
I flashed to the latest f/w manually but the problem persists.
  • FURRYe38's avatar
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    • Jjersey63's avatar
      Jjersey63
      Apprentice
      So I rebooted everything in order, waited and all works but still the same results.  I didn’t factory reset - what is the best way to do this?  I have a backup config to restore.
      • FURRYe38's avatar
        I would use the RBRs web page under Advance tab/Advanced/Backup and use the Erase button here. When you do this, I would then press the reset button on the RBS for 15 seconds then release. Walk thru the setup wizard using a wired PC and web browser and complete the setup process. I would first check the RBS on the RBRs web page after you complete the setup wizard and see what it shows.
      Jjersey63
      Apprentice
      It’s ATT uverse - Arris NVG589 in passthrough mode.
      Jjersey63
      Apprentice
      Does this help?
      • iyang's avatar
        iyang
        NETGEAR Expert
        Hi Jjersey63 ,
        Thanks.
        Did you use AP mode in Orbi ?
        And did you power off/ on the satellite ?
