BB69
Jun 11, 2026Aspirant
RBR760 with firmware v6.3.8.5_1.4.80
Exact same issue here, using RBR760 with firmware v6.3.8.5_1.4.80 terrible muisance!
BB69
Aug 05, 2026Aspirant
Just to provide some feedback: firmware 6.3.8.11 has not resolved my issue of occasionally loosing configuration on reboot.
And Netgear support have not been able to restore my SPC functionality so far, despite spending lost of hours troubleshooting and lots of chats and phone calls.
They are currently in the process of refunding the paid SPC subscription, not really the solution I hoped for.
- FURRYe38Aug 05, 2026Guru - Experienced User
Thank you for letting us know.
You may need to find an alternative for your needs.
Good Luck.
- BB69Aug 06, 2026Aspirant
Going for an alternative indeed: just ordered a Firewalla purple SE to get the SPC functionality I need (+much more I guess...) And will use the Netgear devices as Access Point only.
Let's see how that works out!
- FURRYe38Aug 06, 2026Guru - Experienced User
That should work well. Let us know how it turns out.
