BB69
Jun 11, 2026Aspirant
RBR760 with firmware v6.3.8.5_1.4.80
Exact same issue here, using RBR760 with firmware v6.3.8.5_1.4.80 terrible muisance!
BB69
Aug 05, 2026Aspirant
Just to provide some feedback: firmware 6.3.8.11 has not resolved my issue of occasionally loosing configuration on reboot.
And Netgear support have not been able to restore my SPC functionality so far, despite spending lost of hours troubleshooting and lots of chats and phone calls.
They are currently in the process of refunding the paid SPC subscription, not really the solution I hoped for.
Aug 05, 2026Guru - Experienced User
Thank you for letting us know.
You may need to find an alternative for your needs.
Good Luck.
- BB69Aug 06, 2026Aspirant
Going for an alternative indeed: just ordered a Firewalla purple SE to get the SPC functionality I need (+much more I guess...) And will use the Netgear devices as Access Point only.
Let's see how that works out!
- FURRYe38Aug 06, 2026Guru - Experienced User
That should work well. Let us know how it turns out.
- BB69Aug 13, 2026Aspirant
The Firewalla is doing great so far, as is the app that goes with it. Great SPC functionality!
But the ORBI still has the ‘loss of configuration on reboot’ issue, even when 'only' configured as AP.
About 1 out of 2 reboots result in loss of configuration with exception of the wireless network settings. Either by power cycle or reboot from the web interface, no different…. I have ditched the ORBI app for now, just using the web interface which is much quicker and less cumbersome than the app.
I had a 2nd RBR760 lying around, so I decided to see if that has the same issue and it does.
I am considering opening another case, but my previous case has been very time-consuming and has not resulted in any useful outcome. So not sure if it’s worth the time and effort...
I do see more reports on this exact same loss of configuration issue, has anyone found a fix or workaround?
Cheers!
