gt7486c
Jun 10, 2022Aspirant
RBR840 - Very SLow UI - Suggestions please
Summary: When logging into the Orbi web interface, the UI is really slow and unresponsive. I mean clicking on things often takes a few seconds to show up. I've had Orbi many years ago and returned bu...
- Jun 10, 2022
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?85 devices is a lot of devices.
I would try this, you could leave the RBS ON and let wifi devices connect to them.
Disconnect all but 1 wired PC to the RBR. Disconnect all other cable lines including the cable to the ISP modem.
Factory reset the RBR and setup from scratch using the wired PC and web browser at HTTP and 192.168.1.1. Walk thru the setup wizard taking notice of any slowness as you go thru the wizard. Don't set SSID and PW to same as before right now.
When you get to the home screen, select a few areas to go into and take notice of any slowness in browsing the RBRs web pages. Does the slowness still continue?
After checking this, connect the RBR to the ISP modem and check RBRs web pages again.
After checking this, set the RBR SSID and Password to what you had before. RBS and devices should connect and check web pages again.
Let us know how it turns out.
Jun 10, 2022Guru - Experienced User
