RBaptist
May 12, 2023Aspirant
RBR840 limited to 100 MB
RBR840 limited to 100 MB. Up to a week ago I was getting 940 MB up and down wireless and LAN, now only 100 on both. 1G fiber verified. And I checked Cat-5e and 6. Also software is up-to-date.
May 12, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Check your PCs ethernet adapter for connection rate to the back of the RBR. Should read 1000Mbps. Can also check the connection rate as well on the RBRs web page under Advanced tab/Show Stats button.
Check the PC connected to the ISP modem/ONT directly and using Ooklas installable speed test app.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
- RBaptistMay 12, 2023Aspirant
Restarted modem and ORBI
V4.6.14.3_2.3.12
AT&T BGW320-500
Cat-6, yes
WAN 100M/Full
Test 972 Down, 951 Up
- FURRYe38May 12, 2023Guru - Experienced User
So the port on the RBR is reading 100Mpbs connection rate to the PC?
What is the connection rate seen on the WAN port to the ISP modem?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
https://kb.netgear.com/19863/Ping-Test-to-determine-Optimal-MTU-Size-on-RouterTry option #2 first...
The Wi-Fi in the AT&T modem is disabled and the speeds were perfect up to 10 days ago. The WAN port reads 100 when I move the cable to a LAN port it reads 1000.
