RBaptist
May 12, 2023Aspirant
RBR840 limited to 100 MB
RBR840 limited to 100 MB. Up to a week ago I was getting 940 MB up and down wireless and LAN, now only 100 on both. 1G fiber verified. And I checked Cat-5e and 6. Also software is up-to-date.
RBaptist
Restarted modem and ORBI
V4.6.14.3_2.3.12
AT&T BGW320-500
Cat-6, yes
WAN 100M/Full
Test 972 Down, 951 Up
May 12, 2023Guru - Experienced User
So the port on the RBR is reading 100Mpbs connection rate to the PC?
What is the connection rate seen on the WAN port to the ISP modem?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
https://kb.netgear.com/19863/Ping-Test-to-determine-Optimal-MTU-Size-on-Router
- RBaptistMay 12, 2023Aspirant
The Wi-Fi in the AT&T modem is disabled and the speeds were perfect up to 10 days ago. The WAN port reads 100 when I move the cable to a LAN port it reads 1000.
