bobswinkle
Sep 22, 2024Follower
RBR850 - Not blocking services
I have two RBR850 connected in a mesh. I'm trying to setup the block sites and block services features. Neither are working as expected.
The block services one is most important to me. I want to setup a block for Steam to eventually schedule it.
I've done the following:
These are the steam ports per this website: https://help.steampowered.com/en/faqs/view/2EA8-4D75-DA21-31EB
I've tried a reboot of all relevant devices after hitting apply. Everything on steam is working as expected. I've also checked for new firmware and I'm on the latest version.
At a bit of a loss, keen to get some help.
Cheers
1 Reply
the https causes issues and basically ruined blocking on the netgear routers.
https://aws.amazon.com/compare/the-difference-between-https-and-http/
For most, using a DNS blocker works better. I use pihole but you could use a direct service like cloudfare or opendns
