Malp
Mar 09, 2025Follower
RBR850 + 2xRBS850 Satellite Firmware Update Issue
Hi there! I had some issues with connectivity so I took the plunge and reset my RBR850, then updated the firmware finally to 7.2.7.15_5.1.16. The 2x RBS850s connected without issue but I cannot ...
- Mar 09, 2025
You need to update any and ALL RBS FIRST before the RBR is.
Downgrade the RBR back to v4 FW, then manually update the RBS first.Follow this PDF Process:
After you have the RBS updated then update the RBR lastly, factory reset the system and setup from scratch using this PDF process:
I just did this with my 854 series system and is working great.
Mar 09, 2025Guru - Experienced User
