Scottrya
Mar 18, 2020Follower
RBR850 & RBS40V Compatibility
Is it likely that the RBS40V will be made compatible with the RBR850. Just upgraded my mesh network but unable to add the Alexa Satellite, which is a great piece of kit. Just don’t want to unnecessarily spend time replace
1 Reply
- ekhalilMaster
It should work now if you connect the RBS40V wired to the RBR850.
Wireless connectivity to original Orbi will come later as promised by Netgear.
