tcappetti
Nov 30, 2020Aspirant
RBR850 Anywhere access not working
Version: 3.2.16.22 Anywhere Access and Speedtest donot work!!
- Dec 01, 2020
I did the factory reset that solved all problems I had. Thanks
Nov 30, 2020Guru - Experienced User
a factory reset and setup from scratch differs from a reboot. Press the reset button for 15 seconds on the RBR and release. Walk thru the setup wizard.
Also FYI:
Something you may want to try with the newer version of FW if you haven't.
