rtrueman's avatar
rtrueman
RBR850 Firmware V3.2.17.12_1.4.14
I manually updated my RBR850 and Satellite with the 3.2.17.12 firmware and having random disconnects since. Anyone else? This is the first time I've run into issues in the 6+ months that I've used it.
RT
  • FURRYe38's avatar
    Has a reset and setup from scratch been performed since update?
    Is Traffic Meter enabled? If so, disable this...
    • rtrueman's avatar
      rtrueman
      Thanks for the reply! I've rebooted, but not reset and setup from scratch. Is that really needed for every firmware upgrade? Yikes! No, the traffic meter is off (double-checked to make sure). I'm connected directly to my Verizon FIOS ONT.
      • FURRYe38's avatar
        Sometimes yes.
        Is there any router built in to the ONT or is it just a ONT only?
