ssgtweasel
Feb 13, 2021Guide
RBR850-frequently issuing DNS error in browsers then refreshes and proceeds to applicable webpage
Noticing intermittant issues on several of my home PCs, when opening webrower and type in an URL, I'll get an DNS probe error for maybe 2secs then automatically will open the intended webpage
Happens regardless of hard wired or wifi
using suddenlink cable modem only
RBR50 and BRS50 using latest firmware
THis doesn't happenn every instance though
Using ISP DHCP settings - haven't change to 8.8.8.8 or 8.8.4.4 in either cable modem setting or PCs
I found a similiar post from 2020 however I would have thought this issue may have already been addressed
Not using circle however using netamor
Firmware Version
V3.2.17.12_1.4.14
- Ok thanks but
It’s dated oct 2020 and not real resolution unless I missed it
I don’t enter to manually set google dns in each deviceUnfortunately the issue still exists and not solved by the latest Orbi AX firmware for the subset of customers impacted by this bug. Follow the main thread if you want to watch for any new progress.
