Hineman's avatar
Hineman
Initiate
May 07, 2020
RBR850 IP Address Error
Hello everyone.  Just got my new 3 pack of the Orbi 6 and when I set up the system today the main router and one satelite set up great, however the 2nd satelite somehow has been assigned a IP address that is not part of the network.  So it connects but nothing connected to it will connect.  I have tried to do a physical reset, I have tried to pair it again, I have tried to connect it with a cable instead wireless to the router.  Any suggestions on how to get this 2nd satelite working properly.  Would prefer not to have to set up the whole thing again.  Have not been able to update this ones firmware due to this issue.  The router and the other satelite upgraded firmware fine.
  • Update - Solved by changing the IP address on the router.  Did not want to do it but it was quite quick..
    Thanks.
    Thanks.
    • FURRYe38's avatar
      Glad you got it working. If you have a router front of the RBR, this router maybe using same 192.168.1.1 string as the RBR. You can always change the RBRs IP address to avoid conflicts as well. I use 192.168.0.1.
      Enjoy. :smileywink:
