Kelsett
Apr 24, 2020Tutor
RBR850 NAT loopback
Hello, I'm hosting a webserver at home. The site is perfectly accessible from outside the network. When I try to access it from inside the network, it works via wifi but won't work on an ethe...
kildare
Apr 24, 2020Luminary
Currently Orbi AX is not yet included in the list of NETGEAR products that support NAT loopback:
https://kb.netgear.com/000049578/NETGEAR-Router-support-for-NAT-Loopback
- KelsettApr 24, 2020Tutor
Thank you for the link. It's interesting that it works via Wifi though.
Does anyone know if/when this feature will be completely implemented ?
Thanks
- gb777Jun 19, 2020Apprentice
I can confirm the lack of proper support for NAT loopback with a newly bought RBR750 (AX4200).
Very disappointing.
Netgear maintains a website with the subset of products that work correctly:
- FURRYe38Jun 19, 2020Guru - Experienced User
Something to post about here:
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
- jasuehNov 02, 2020Aspirant
kildare wrote:Currently Orbi AX is not yet included in the list of NETGEAR products that support NAT loopback:
I just checked the KB and it seems that RBR850 was added to the list.
That doesn't mean that it works, I'm able to access a resource using an external connection but not using the public IP from within the LAN.- whoDeanNov 08, 2020Guide
Same, NAT loopback isn't working for me on the RBR850. Basically devices connected via Ethernet cannot talk to devices connected to Wifi (same Router).
- Mikey94025Nov 08, 2020Hero
whoDean wrote:Same, NAT loopback isn't working for me on the RBR850. Basically devices connected via Ethernet cannot talk to devices connected to Wifi (same Router).
That is not the same problem as NAT loopback. NAT loopback is when the public IP address or domain name of the server does not work within the local network (and presumably the local IP address or name still works).
If your wired and wireless devices cannot communicate with each other then that is probably a different problem. They can't ping each other's local IP addresses? Do you have any network switches between your Orbi and the wired devices? Some network switches, particularly "managed" or "green" ones, cause connectivity problems within the Orbi local network.
