badelaide
Dec 09, 2025Aspirant
RBR850 not adjusting daylight savings time for Australia / Adelaide timezone
Settings under Administration > NTP Settings. Doesn't matter which NTP server is being used. Works and adjusts DST correctly for the Brisbane / Sydney / Melbourne timezone and others work correct...
Dec 13, 2025Guru - Experienced User
Wondering if thats due to the 30 minute off set time for the region select?
Had this been working before?
Checking my RBR850, Selecting Adelaide and selecting and un checking the DST box, doesn't change the time at all. Selecting Brisbane...selecting and unchecking the DST box does change the time by an hour.
What FW version do you have on the RBR?
badelaide
Dec 14, 2025Aspirant
Couldn't say - haven't had it that long so this is the first DST changeover. Agree that it might be the weirdness of the 30min off set timezone...
FW version is V7.2.8.5_5.1.21
- badelaideDec 14, 2025Aspirant
(and hadn't really noticed the time not being right more generally - that said, might be the updated FW as that was updated recently)
- FURRYe38Dec 15, 2025Guru - Experienced User
I checked my 850 and in on a prior v.2 version and what I saw there.
I guess run it as is or use Brisbane instead if you need too.
I've passed this on to NG for review. No idea when or if it will be addressed.
