badelaide
Dec 09, 2025Aspirant
RBR850 not adjusting daylight savings time for Australia / Adelaide timezone
Settings under Administration > NTP Settings. Doesn't matter which NTP server is being used. Works and adjusts DST correctly for the Brisbane / Sydney / Melbourne timezone and others work correct...
Dec 16, 2025Guru - Experienced User
What is the time difference between Australia / Adelaide and Brisbane / Sydney / Melbourne? Is it only 30 minutes difference or something more then that?
- StephenBDec 16, 2025Guru - Experienced User
Adelaide: GMT+10:30
Brisbane: GMT+10
Melbourne,Sidney: GMT+11
