srosenthal33's avatar
srosenthal33
Follower
Feb 28, 2024
RBR850 Not getting 2gb speed Xfinty
I upgraded to Xfinity 2gb speed.  When I run a speed test within the Orbi app it shows I am getting 1gb to the Orbi.  Is there a setting I need to change or why am I only getting 1gb to the Orbi?
1 Reply
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed?
    Turn off and unplug modem.
    Turn on computers and rest of network.
