t_tr
Nov 18, 2021Aspirant
RBR850 showing 2 domains out of the box
Just installed RBR850 / (2) RBS850 and seeing 2 IP strings under Attached Devices including 192.168.1.xx and 192.168.2.xx. The router was configured for DHCP. Called Netgear support who suggested changing the channel for the main network (I assume to test that it can support a change). Upon doing so the main network never recovered while the Guest network is the only functioning connection to the router. I am unable to access the admin screen to login from App or web browser on either 192.168.2.1 / 192.168.1.1. Any suggestions?
Please post a screen capture of what your seeing. Use the Choose File button on your next post.
192.168.1.1 is for the main netowrk. 192.168.2.1 is for Guest WiFi Network.
